NVMe not always detected at boot
I have a NanoPC-T6 and the NVMe is not always detected at boot.
This happens both after a cold boot (power on) and following a warm boot (using reboot command)
Installed NVMe is 1TB WD Blue SN570.
Installed image is rk3588-eflasher-debian-bullseye-desktop-5.10-arm64-20230515.img.gz
Following failure I ran dmesg |grep nvme which showed the following
[ 3.797810] nvme 0000:01:00.0: of_irq_parse_pci: failed with rc=134
[ 3.798124] nvme nvme0: pci function 0000:01:00.0
[ 3.798317] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[ 3.798390] nvme nvme0: Removing after probe failure status: -19
Following a failure, I issued the command dmesg |grep -i fail with the results below, which includes several power-management related failures
[ 2.260526] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@00000000': base 0x0000000000000000, size 0 MiB
[ 2.942764] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply property in node /power-management@fd8d8000/power-controller failed
[ 2.942997] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply property in node /power-management@fd8d8000/power-controller failed
[ 2.943148] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply property in node /power-management@fd8d8000/power-controller failed
[ 2.944183] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply property in node /power-management@fd8d8000/power-controller failed
[ 2.944314] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply property in node /power-management@fd8d8000/power-controller failed
[ 2.944409] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply property in node /power-management@fd8d8000/power-controller failed
[ 2.944644] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply property in node /power-management@fd8d8000/power-controller failed
[ 2.944888] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply property in node /power-management@fd8d8000/power-controller failed
[ 3.333109] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed
[ 3.333148] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed
[ 3.334059] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply property in node /syscon@fd5d8000/usb2-phy@8000/host-port failed
[ 3.334851] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply property in node /syscon@fd5dc000/usb2-phy@c000/host-port failed
[ 3.335929] phy phy-fd5d4000.syscon:usb2-phy@4000.3: Looking up vbus-supply property in node /syscon@fd5d4000/usb2-phy@4000/otg-port failed
[ 3.337276] phy phy-fee00000.phy.4: Looking up phy-supply property in node /phy@fee00000 failed
[ 3.337378] phy phy-fee20000.phy.5: Looking up phy-supply property in node /phy@fee20000 failed
[ 3.337523] phy phy-fee10000.phy.6: Looking up phy-supply property in node /phy@fee10000 failed
[ 3.338014] phy phy-fed60000.hdmiphy.7: Looking up phy-supply property in node /hdmiphy@fed60000 failed
[ 3.338682] phy phy-fed70000.hdmiphy.8: Looking up phy-supply property in node /hdmiphy@fed70000 failed
[ 3.339381] phy phy-fee80000.phy.9: Looking up phy-supply property in node /phy@fee80000 failed
[ 3.339909] phy phy-fed80000.phy.10: Looking up phy-supply property in node /phy@fed80000/dp-port failed
[ 3.339934] phy phy-fed80000.phy.11: Looking up phy-supply property in node /phy@fed80000/u3-port failed
[ 3.340134] phy phy-fed90000.phy.12: Looking up phy-supply property in node /phy@fed90000/u3-port failed
[ 3.360288] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
[ 3.361528] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc38000 failed
[ 3.362128] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc48000 failed
[ 3.363565] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply property in node /power-management@fd8d8000/power-controller failed
[ 3.380112] rockchip-drm display-subsystem: failed to get hdmi0_phy_pll: -2
[ 3.380118] rockchip-drm display-subsystem: failed to get hdmi1_phy_pll: -2
[ 3.390526] rockchip-drm display-subsystem: route-hdmi0: failed to get logo,offset
[ 3.390540] rockchip-drm display-subsystem: failed to show kernel logo
[ 3.697387] sdhci-dwcmshc fe2e0000.mmc: Looking up vmmc-supply property in node /mmc@fe2e0000 failed
[ 3.697409] sdhci-dwcmshc fe2e0000.mmc: Looking up vqmmc-supply property in node /mmc@fe2e0000 failed
[ 3.698458] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[ 3.745762] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply property in node /power-management@fd8d8000/power-controller failed
[ 3.794671] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x40000000]
[ 3.794692] pci 0000:00:00.0: BAR 1: failed to assign [mem size 0x40000000]
[ 3.835879] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fd8d8000/power-controller failed
[ 3.836689] vdd_gpu_s0: Failed to create debugfs directory
[ 3.836730] vdd_gpu_s0: Failed to create debugfs directory
[ 3.837309] vdd_gpu_s0: Failed to create debugfs directory
[ 3.839725] vdd_ddr_s0: Failed to create debugfs directory
[ 3.840043] vdd_log_s0: Failed to create debugfs directory
[ 3.842170] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 3.842179] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 3.867038] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply property in node /power-management@fd8d8000/power-controller failed
[ 3.867135] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gmac-supply property in node /power-management@fd8d8000/power-controller failed
[ 3.867216] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply property in node /power-management@fd8d8000/power-controller failed
[ 3.872550] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply property in node /power-management@fd8d8000/power-controller failed
[ 3.872675] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply property in node /power-management@fd8d8000/power-controller failed
[ 3.872778] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply property in node /power-management@fd8d8000/power-controller failed
[ 3.872971] vdd_npu_s0: Failed to create debugfs directory
[ 3.873467] vdd_npu_s0: Failed to create debugfs directory
[ 3.874101] vdd_npu_s0: Failed to create debugfs directory
[ 3.900210] RKNPU fdab0000.npu: failed to find power_model node
[ 3.900246] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
[ 3.900259] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
[ 5.764245] at24 6-0053: Looking up vcc-supply property in node /i2c@fec80000/eeprom@53 failed
[ 5.896319] systemd-journald[390]: Failed to read journal file /var/log/journal/b7f54c1a952e4bada76f5d6f95ef6e22/user-1000.journal for rotation, trying to move it out of the way: Device or resource busy
[ 5.907110] systemd-journald[390]: Failed to read journal file /var/log/journal/b7f54c1a952e4bada76f5d6f95ef6e22/user-1001.journal for rotation, trying to move it out of the way: Device or resource busy
[ 6.745430] rk-pcie fe180000.pcie: PCIe Link Fail
[ 6.745473] rk-pcie fe180000.pcie: failed to initialize host
dmesg also included the following
[ 6.160328] ------------[ cut here ]------------
[ 6.160350] WARNING: CPU: 6 PID: 56 at drivers/usb/dwc3/gadget.c:3893 dwc3_stop_active_transfer.part.0+0xbc/0xd0
[ 6.160354] Modules linked in: l2tp_ppp l2tp_netlink l2tp_core ip6_udp_tunnel udp_tunnel pppox at24 rtc_hym8563 r8169 uio_pdrv_genirq uio binfmt_misc r8125(O) ledtrig_netdev ip_tables
[ 6.160378] CPU: 6 PID: 56 Comm: kworker/6:1 Tainted: G O 5.10.110 #1
[ 6.160382] Hardware name: FriendlyElec NanoPC-T6 (DT)
[ 6.160389] Workqueue: pm pm_runtime_work
[ 6.160395] pstate: 20c00089 (nzCv daIf +PAN +UAO -TCO BTYPE=--)
[ 6.160399] pc : dwc3_stop_active_transfer.part.0+0xbc/0xd0
[ 6.160402] lr : dwc3_stop_active_transfer.part.0+0x80/0xd0
[ 6.160406] sp : ffffffc0125dbb30
[ 6.160409] x29: ffffffc0125dbb30 x28: ffffffc01210c748
[ 6.160413] x27: ffffffc011e048a0 x26: ffffffc011de7000
[ 6.160418] x25: 00000000ca42691f x24: ffffff8104076400
[ 6.160423] x23: ffffff810162ebc8 x22: 0000000000000000
[ 6.160429] x21: ffffff81040a41c0 x20: 0000000000000000
[ 6.160434] x19: ffffff81040aea00 x18: ffffffff04291300
[ 6.160438] x17: 0000000000000001 x16: 000000000172d858
[ 6.160442] x15: 0000000001b9fe98 x14: ffffffc011e08df0
[ 6.160446] x13: 0000000000006f0f x12: ffffffffffff3f08
[ 6.160449] x11: 01b0860283307d70 x10: ffffffffffff3f04
[ 6.160453] x9 : ffffffc010af2270 x8 : ffffffffffff3f00
[ 6.160457] x7 : ffffffffffff3f0c x6 : 0000000008ceb846
[ 6.160462] x5 : ffffffffffff3f0c x4 : ffffffc011dea000
[ 6.160466] x3 : 0000000000101448 x2 : 0000000000000000
[ 6.160470] x1 : ffffffc014000100 x0 : 00000000ffffff92
[ 6.160474] Call trace:
[ 6.160477] dwc3_stop_active_transfer.part.0+0xbc/0xd0
[ 6.160481] dwc3_remove_requests.constprop.0+0x3c/0x100
[ 6.160485] __dwc3_gadget_ep_disable+0x74/0x174
[ 6.160488] dwc3_gadget_suspend+0x54/0xe0
[ 6.160494] dwc3_suspend_common+0xe0/0x204
[ 6.160498] dwc3_runtime_suspend+0x38/0x70
[ 6.160503] pm_generic_runtime_suspend+0x38/0x50
[ 6.160508] genpd_runtime_suspend+0xb4/0x2f0
[ 6.160511] __rpm_callback+0x98/0x1b0
[ 6.160515] rpm_callback+0x2c/0x90
[ 6.160518] rpm_suspend+0x110/0x620
[ 6.160521] pm_runtime_work+0xd0/0xd4
[ 6.160528] process_one_work+0x1c8/0x440
[ 6.160532] worker_thread+0x78/0x434
[ 6.160535] kthread+0x130/0x134
[ 6.160540] ret_from_fork+0x10/0x3c
[ 6.160543]
PC: 0xffffffc010af22ac:
[ 6.160546] 20ac f9419ac0 b9404800 7100101f 54ffd468 17ffff86 b0007240 91002000 d53cd042
[ 6.160555] 20cc b8626802 900097c4 91272084 7100005f 1100fc40 1a82b000 13067c00 93407c00
[ 6.160563] 20ec f8607880 9ac22400 3607d220 d000acc0 912c0000 f9402000 b40000c0 f9400400
[ 6.160571] 210c 92981fed 52984002 8b0d0021 97ffeb57 17fffe87 12197803 37400080 52800800
[ 6.160578] 212c b9006fe0 17ffff5b 52802801 2a0303e0 b9006fe1 17ffff56 aa1e03e9 d503201f
[ 6.160586] 214c d503233f a9bd7bfd d5384101 910003fd 39433003 f9428822 f90017e2 d2800002
[ 6.160594] 216c 528000a1 f9404c02 36000163 b9442844 528aa663 6b03009f 54000280 f9419843
[ 6.160602] 218c 528000a1 528100a2 b9404863 6b01007f 1a823021 910073e2 f801c3ff b90027ff
[ 6.160611] 21ac 97fffe4e d5384101 f94017e3 f9428822 eb020063 d2800002 54000141 a8c37bfd
[ 6.160619] 21cc d50323bf d65f03c0 b9442c44 5284c123 72aaa663 6b03009f 54fffde9 17ffffe8
[ 6.160627] 21ec 9418b7a1 aa1e03e9 d503201f d503233f a9bc7bfd d5384103 910003fd a90153f3
[ 6.160635] 220c 53151c21 aa0003f3 f9428864 f9001fe4 d2800004 3942b003 72001c54 2a034023
[ 6.160643] 222c 54000180 52802101 9100b3e2 2a010061 f802c3ff b90037ff 97fffe28 35000320
[ 6.160651] 224c 3902b27f b940a660 321c0000 1400000a 321d0061 9100b3e2 f802c3ff b90037ff
[ 6.160659] 226c 97fffe1e 350001e0 3902b27f b940a660 121c7800 b900a660 d5384100 f9401fe2
[ 6.160667] 228c f9428801 eb010042 d2800001 54000121 a94153f3 a8c47bfd d50323bf d65f03c0
[ 6.160675] 22ac* d4210000 3902b27f 35fffcf4 17fffff0 9418b76d d503245f aa1e03e9 d503201f
[ 6.160682] 22cc b940a403 52840304 0a040063 7100207f 54000141 d503233f a9bf7bfd 12001c21
[ 6.160690] 22ec 910003fd 12001c42 97ffffbf a8c17bfd d50323bf d65f03c0 d65f03c0 d503201f
[ 6.160698] 230c d503201f aa1e03e9 d503201f d503233f a9b87bfd d5384102 910003fd a90153f3
[ 6.160706] 232c aa0003f3 a9025bf5 a90363f7 2a0103f8 a9046bf9 f9428840 f9003fe0 d2800000
[ 6.160714] 234c b940a660 f9401e76 f9404e75 37000ec0 b9449aa1 aa1503f9 3942aa62 36500901
[ 6.160721] 236c 39c00ac1 36f808c1 7100045f 54000889 37600dc0 a90573fb 39400ec0 12000400
[ 6.160730] 238c 7100041f 54002d40 7100081f 540030a0 71000c1f 54003201 5280003c 52800814
[ 6.160738] 23ac b9442b21 52866640 39512737 6b00003f 54000081 b9446320 12180400 2a0002f7
[ 6.160745] 23cc b9444f20 53037ef7 36b02d20 7948cb3a 531f7ae2 0b1402f4 51000442 b944a73b
[ 6.160753] 23ec f941cb20 52986001 1b1c0a94 97fff776 12103c03 b9442b21 528aa660 1ad70a94
[ 6.160761] 240c 0b1b4063 6b00003f 12003a80 0b342361 0b1b0000 2a140063 1a811014 6b1a029f
[ 6.160769] 242c 54002f42 3942aa62 52861800 f941cb21 0b420402 531e7442 d50332bf 92981fe0
[ 6.160777] 244c 8b22c000 8b000020 b9000003 d503201f b940a660 32140000 b900a660 b904a734
[ 6.160784] 246c b944ab20 11000400 b904ab20 a94573fb 3942aa62 f9404e79 d503201f 35002222
[ 6.160792] 248c 910183e2 aa1303e0 52800121 f90033ff b9006bff 97fffd91 2a0003f4 35000280
[ 6.160800]
LR: 0xffffffc010af2270:
[ 6.160803] 2070 3607dda0 d000acc0 912c0000 f9402000 b40000c0 f9400400 92981fe2 8b020021
[ 6.160811] 2090 52984002 97ffeb78 17fffee3 f9400062 17ffffdd f9400062 17ffff09 f9419ac0
[ 6.160819] 20b0 b9404800 7100101f 54ffd468 17ffff86 b0007240 91002000 d53cd042 b8626802
[ 6.160826] 20d0 900097c4 91272084 7100005f 1100fc40 1a82b000 13067c00 93407c00 f8607880
[ 6.160834] 20f0 9ac22400 3607d220 d000acc0 912c0000 f9402000 b40000c0 f9400400 92981fed
[ 6.160842] 2110 52984002 8b0d0021 97ffeb57 17fffe87 12197803 37400080 52800800 b9006fe0
[ 6.160850] 2130 17ffff5b 52802801 2a0303e0 b9006fe1 17ffff56 aa1e03e9 d503201f d503233f
[ 6.160858] 2150 a9bd7bfd d5384101 910003fd 39433003 f9428822 f90017e2 d2800002 528000a1
[ 6.160866] 2170 f9404c02 36000163 b9442844 528aa663 6b03009f 54000280 f9419843 528000a1
[ 6.160873] 2190 528100a2 b9404863 6b01007f 1a823021 910073e2 f801c3ff b90027ff 97fffe4e
[ 6.160881] 21b0 d5384101 f94017e3 f9428822 eb020063 d2800002 54000141 a8c37bfd d50323bf
[ 6.160889] 21d0 d65f03c0 b9442c44 5284c123 72aaa663 6b03009f 54fffde9 17ffffe8 9418b7a1
[ 6.160897] 21f0 aa1e03e9 d503201f d503233f a9bc7bfd d5384103 910003fd a90153f3 53151c21
[ 6.160905] 2210 aa0003f3 f9428864 f9001fe4 d2800004 3942b003 72001c54 2a034023 54000180
[ 6.160912] 2230 52802101 9100b3e2 2a010061 f802c3ff b90037ff 97fffe28 35000320 3902b27f
[ 6.160920] 2250 b940a660 321c0000 1400000a 321d0061 9100b3e2 f802c3ff b90037ff 97fffe1e
[ 6.160928] 2270* 350001e0 3902b27f b940a660 121c7800 b900a660 d5384100 f9401fe2 f9428801
[ 6.160936] 2290 eb010042 d2800001 54000121 a94153f3 a8c47bfd d50323bf d65f03c0 d4210000
[ 6.160943] 22b0 3902b27f 35fffcf4 17fffff0 9418b76d d503245f aa1e03e9 d503201f b940a403
[ 6.160951] 22d0 52840304 0a040063 7100207f 54000141 d503233f a9bf7bfd 12001c21 910003fd
[ 6.160959] 22f0 12001c42 97ffffbf a8c17bfd d50323bf d65f03c0 d65f03c0 d503201f d503201f
[ 6.160966] 2310 aa1e03e9 d503201f d503233f a9b87bfd d5384102 910003fd a90153f3 aa0003f3
[ 6.160974] 2330 a9025bf5 a90363f7 2a0103f8 a9046bf9 f9428840 f9003fe0 d2800000 b940a660
[ 6.160982] 2350 f9401e76 f9404e75 37000ec0 b9449aa1 aa1503f9 3942aa62 36500901 39c00ac1
[ 6.160990] 2370 36f808c1 7100045f 54000889 37600dc0 a90573fb 39400ec0 12000400 7100041f
[ 6.160997] 2390 54002d40 7100081f 540030a0 71000c1f 54003201 5280003c 52800814 b9442b21
[ 6.161005] 23b0 52866640 39512737 6b00003f 54000081 b9446320 12180400 2a0002f7 b9444f20
[ 6.161013] 23d0 53037ef7 36b02d20 7948cb3a 531f7ae2 0b1402f4 51000442 b944a73b f941cb20
[ 6.161020] 23f0 52986001 1b1c0a94 97fff776 12103c03 b9442b21 528aa660 1ad70a94 0b1b4063
[ 6.161028] 2410 6b00003f 12003a80 0b342361 0b1b0000 2a140063 1a811014 6b1a029f 54002f42
[ 6.161036] 2430 3942aa62 52861800 f941cb21 0b420402 531e7442 d50332bf 92981fe0 8b22c000
[ 6.161044] 2450 8b000020 b9000003 d503201f b940a660 32140000 b900a660 b904a734 b944ab20
[ 6.161052]
SP: 0xffffffc0125dbb30:
[ 6.161055] b930 125db9e0 ffffffc0 125dba10 ffffffc0 125db960 ffffffc0 1002b4e8 ffffffc0
[ 6.161063] b950 125db9e0 ffffffc0 00000001 00000000 125db9a0 ffffffc0 1111f0e4 ffffffc0
[ 6.161070] b970 125db9e0 ffffffc0 f2000800 00000000 88ce7bf4 0000007f 10af22ac ffffffc0
[ 6.161078] b990 125db9a0 ffffffc0 1111f0d4 ffffffc0 125db9d0 ffffffc0 1111f528 ffffffc0
[ 6.161086] b9b0 040aea00 ffffff81 ffffffff 0000007f 125dbb30 ffffffc0 100a96a0 ffffffc0
[ 6.161094] b9d0 125dbb10 ffffffc0 1000240c ffffffc0 ffffff92 00000000 14000100 ffffffc0
[ 6.161102] b9f0 00000000 00000000 00101448 00000000 11dea000 ffffffc0 ffff3f0c ffffffff
[ 6.161109] ba10 08ceb846 00000000 ffff3f0c ffffffff ffff3f00 ffffffff 10af2270 ffffffc0
[ 6.161117] ba30 ffff3f04 ffffffff 83307d70 01b08602 ffff3f08 ffffffff 00006f0f 00000000
[ 6.161125] ba50 11e08df0 ffffffc0 01b9fe98 00000000 0172d858 00000000 00000001 00000000
[ 6.161133] ba70 04291300 ffffffff 040aea00 ffffff81 00000000 00000000 040a41c0 ffffff81
[ 6.161140] ba90 00000000 00000000 0162ebc8 ffffff81 04076400 ffffff81 ca42691f 00000000
[ 6.161148] bab0 11de7000 ffffffc0 11e048a0 ffffffc0 1210c748 ffffffc0 125dbb30 ffffffc0
[ 6.161156] bad0 10af2270 ffffffc0 125dbb30 ffffffc0 10af22ac ffffffc0 20c00089 00000000
[ 6.161164] baf0 0162ebc8 ffffff81 04076400 ffffff81 ffffffff ffffffff 11de7000 ffffffc0
[ 6.161172] bb10 125dbb30 ffffffc0 10af22ac ffffffc0 00000000 00000000 11128ab4 00000040
[ 6.161179] bb30* 125dbb70 ffffffc0 10af426c ffffffc0 040aea00 ffffff81 040a4080 ffffff81
[ 6.161187] bb50 040b6c00 ffffff81 102698bc 00000000 00000000 00000000 f4059800 b37418ae
[ 6.161195] bb70 125dbb90 ffffffc0 10af5a44 ffffffc0 040aea00 ffffff81 040a4080 ffffff81
[ 6.161202] bb90 125dbbb0 ffffffc0 10af6d94 ffffffc0 040a4080 ffffff81 00000000 00000000
[ 6.161210] bbb0 125dbbd0 ffffffc0 10aeb220 ffffffc0 040a4080 ffffff81 10096e20 ffffffc0
[ 6.161218] bbd0 125dbc00 ffffffc0 10aeb37c ffffffc0 0402e010 ffffff81 0402e010 ffffff81
[ 6.161226] bbf0 0162e880 ffffff81 100fa334 ffffffc0 125dbc20 ffffffc0 109a99e8 ffffffc0
[ 6.161234] bc10 0402e010 ffffff81 109bb2b0 ffffffc0 125dbc30 ffffffc0 109bb364 ffffffc0
[ 6.161242] bc30 125dbc80 ffffffc0 109ac698 ffffffc0 0402e010 ffffff81 109bb2b0 ffffffc0
[ 6.161250] bc50 109bb2b0 ffffffc0 0402e110 ffffff81 00000000 00000000 11122b00 ffffffc0
[ 6.161259] bc70 000f4240 00000000 109ac6d0 ffffffc0 125dbcc0 ffffffc0 109ac7dc ffffffc0
[ 6.161267] bc90 0402e010 ffffff81 109bb2b0 ffffffc0 00000008 00000000 00000000 00000000
[ 6.161275] bcb0 0000000a 00000000 109ae188 ffffffc0 125dbcf0 ffffffc0 109ae1e0 ffffffc0
[ 6.161283] bcd0 0402e010 ffffff81 109bb2b0 ffffffc0 0000000a 00000000 11122b00 ffffffc0
[ 6.161291] bcf0 125dbd70 ffffffc0 109aea00 ffffffc0 0402e1c0 ffffff81 0402e110 ffffff81
[ 6.161298] bd10 f6dd6100 ffffff82 f6ddec00 ffffff82 00000000 00000000 0402e1c8 ffffff81
[ 6.161307]
X1: 0xffffffc014000100:
[ 6.161309] ff00 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161321] ff20 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161329] ff40 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161338] ff60 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161347] ff80 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161356] ffa0 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161365] ffc0 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161374] ffe0 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161382] 0000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161393] 0020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161403] 0040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161414] 0060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161424] 0080 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161434] 00a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161445] 00c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161455] 00e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161466] 0100* 00000001 00000300 00000000 00000000 30c12004 00000000 7e800000 9104018a
[ 6.161477] 0120 5533300a 00000000 00050a6e 02004010 00000000 00000000 00000000 00000000
[ 6.161488] 0140 2020400a 0160c93b 20180101 08290085 47822010 04204108 075e8020 03880800
[ 6.161499] 0160 00420000 41052840 00000000 20000000 003f0000 00000000 00004000 00000000
[ 6.161512] 0180 00000000 00000000 00000000 00000000 00000000 00000000 00000000 0000040d
[ 6.161522] 01a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161533] 01c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161543] 01e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161554] 0200 00101448 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161565] 0220 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161575] 0240 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161586] 0260 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161597] 0280 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161607] 02a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161618] 02c0 010a0002 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161628] 02e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.161639]
X4: 0xffffffc011dea000:
[ 6.161641] 9e00 11de9df8 ffffffc0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.161650] 9e20 11de9e20 ffffffc0 11de9e20 ffffffc0 00000000 dead4ead ffffffff 00000000
[ 6.161657] 9e40 ffffffff ffffffff 11de9e48 ffffffc0 11de9e48 ffffffc0 00000000 dead4ead
[ 6.161665] 9e60 ffffffff 00000000 ffffffff ffffffff 11de9e70 ffffffc0 11de9e70 ffffffc0
[ 6.161673] 9e80 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 11de9e98 ffffffc0
[ 6.161681] 9ea0 11de9e98 ffffffc0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.161689] 9ec0 11de9ec0 ffffffc0 11de9ec0 ffffffc0 00000000 dead4ead ffffffff 00000000
[ 6.161697] 9ee0 ffffffff ffffffff 11de9ee8 ffffffc0 11de9ee8 ffffffc0 00000000 dead4ead
[ 6.161705] 9f00 ffffffff 00000000 ffffffff ffffffff 11de9f10 ffffffc0 11de9f10 ffffffc0
[ 6.161713] 9f20 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 11de9f38 ffffffc0
[ 6.161720] 9f40 11de9f38 ffffffc0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.161729] 9f60 11de9f60 ffffffc0 11de9f60 ffffffc0 00000000 dead4ead ffffffff 00000000
[ 6.161736] 9f80 ffffffff ffffffff 11de9f88 ffffffc0 11de9f88 ffffffc0 00000000 dead4ead
[ 6.161744] 9fa0 ffffffff 00000000 ffffffff ffffffff 11de9fb0 ffffffc0 11de9fb0 ffffffc0
[ 6.161752] 9fc0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 11de9fd8 ffffffc0
[ 6.161760] 9fe0 11de9fd8 ffffffc0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.161767] a000* 11dea000 ffffffc0 11dea000 ffffffc0 00000000 dead4ead ffffffff 00000000
[ 6.161775] a020 ffffffff ffffffff 11dea028 ffffffc0 11dea028 ffffffc0 00000000 dead4ead
[ 6.161783] a040 ffffffff 00000000 ffffffff ffffffff 11dea050 ffffffc0 11dea050 ffffffc0
[ 6.161791] a060 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 11dea078 ffffffc0
[ 6.161799] a080 11dea078 ffffffc0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.161806] a0a0 11dea0a0 ffffffc0 11dea0a0 ffffffc0 00000000 dead4ead ffffffff 00000000
[ 6.161814] a0c0 ffffffff ffffffff 11dea0c8 ffffffc0 11dea0c8 ffffffc0 00000000 dead4ead
[ 6.161822] a0e0 ffffffff 00000000 ffffffff ffffffff 11dea0f0 ffffffc0 11dea0f0 ffffffc0
[ 6.161830] a100 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 11dea118 ffffffc0
[ 6.161838] a120 11dea118 ffffffc0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.161847] a140 11dea140 ffffffc0 11dea140 ffffffc0 00000000 dead4ead ffffffff 00000000
[ 6.161855] a160 ffffffff ffffffff 11dea168 ffffffc0 11dea168 ffffffc0 00000000 dead4ead
[ 6.161862] a180 ffffffff 00000000 ffffffff ffffffff 11dea190 ffffffc0 11dea190 ffffffc0
[ 6.161871] a1a0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 11dea1b8 ffffffc0
[ 6.161879] a1c0 11dea1b8 ffffffc0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.161887] a1e0 11dea1e0 ffffffc0 11dea1e0 ffffffc0 00000000 dead4ead ffffffff 00000000
[ 6.161895]
X5: 0xffffffffffff3f0c:
[ 6.161897] 3d0c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161907] 3d2c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161916] 3d4c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161924] 3d6c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161933] 3d8c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161942] 3dac ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161951] 3dcc ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161960] 3dec ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161969] 3e0c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161978] 3e2c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161987] 3e4c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.161996] 3e6c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162005] 3e8c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162014] 3eac ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162023] 3ecc ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162031] 3eec ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162040] 3f0c* ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162049] 3f2c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162058] 3f4c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162067] 3f6c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162076] 3f8c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162085] 3fac ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162093] 3fcc ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162103] 3fec ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162112] 400c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162122] 402c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162131] 404c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162140] 406c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162149] 408c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162238] 40ac ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162247] 40cc ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162257] 40ec ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162267]
X7: 0xffffffffffff3f0c:
[ 6.162271] 3d0c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162280] 3d2c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162289] 3d4c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162299] 3d6c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162308] 3d8c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162318] 3dac ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162327] 3dcc ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162336] 3dec ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162346] 3e0c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162355] 3e2c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162365] 3e4c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162374] 3e6c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162383] 3e8c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162393] 3eac ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162402] 3ecc ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162411] 3eec ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162421] 3f0c* ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162430] 3f2c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162441] 3f4c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162452] 3f6c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162461] 3f8c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162470] 3fac ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162480] 3fcc ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162489] 3fec ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162498] 400c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162508] 402c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162521] 404c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162532] 406c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162541] 408c ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162550] 40ac ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162560] 40cc ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162569] 40ec ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162579]
X8: 0xffffffffffff3f00:
[ 6.162581] 3d00 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162591] 3d20 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162601] 3d40 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162610] 3d60 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162619] 3d80 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162628] 3da0 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162638] 3dc0 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162647] 3de0 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162657] 3e00 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162667] 3e20 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162676] 3e40 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162685] 3e60 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162694] 3e80 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162705] 3ea0 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162715] 3ec0 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162724] 3ee0 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162734] 3f00* ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162743] 3f20 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162753] 3f40 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162762] 3f60 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162771] 3f80 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162782] 3fa0 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162791] 3fc0 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162801] 3fe0 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162810] 4000 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162819] 4020 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162829] 4040 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162838] 4060 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162848] 4080 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162857] 40a0 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162866] 40c0 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162876] 40e0 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.162886]
X9: 0xffffffc010af2270:
[ 6.162889] 2070 3607dda0 d000acc0 912c0000 f9402000 b40000c0 f9400400 92981fe2 8b020021
[ 6.162897] 2090 52984002 97ffeb78 17fffee3 f9400062 17ffffdd f9400062 17ffff09 f9419ac0
[ 6.162905] 20b0 b9404800 7100101f 54ffd468 17ffff86 b0007240 91002000 d53cd042 b8626802
[ 6.162914] 20d0 900097c4 91272084 7100005f 1100fc40 1a82b000 13067c00 93407c00 f8607880
[ 6.162922] 20f0 9ac22400 3607d220 d000acc0 912c0000 f9402000 b40000c0 f9400400 92981fed
[ 6.162930] 2110 52984002 8b0d0021 97ffeb57 17fffe87 12197803 37400080 52800800 b9006fe0
[ 6.162939] 2130 17ffff5b 52802801 2a0303e0 b9006fe1 17ffff56 aa1e03e9 d503201f d503233f
[ 6.162947] 2150 a9bd7bfd d5384101 910003fd 39433003 f9428822 f90017e2 d2800002 528000a1
[ 6.162956] 2170 f9404c02 36000163 b9442844 528aa663 6b03009f 54000280 f9419843 528000a1
[ 6.162964] 2190 528100a2 b9404863 6b01007f 1a823021 910073e2 f801c3ff b90027ff 97fffe4e
[ 6.162972] 21b0 d5384101 f94017e3 f9428822 eb020063 d2800002 54000141 a8c37bfd d50323bf
[ 6.162980] 21d0 d65f03c0 b9442c44 5284c123 72aaa663 6b03009f 54fffde9 17ffffe8 9418b7a1
[ 6.162989] 21f0 aa1e03e9 d503201f d503233f a9bc7bfd d5384103 910003fd a90153f3 53151c21
[ 6.162997] 2210 aa0003f3 f9428864 f9001fe4 d2800004 3942b003 72001c54 2a034023 54000180
[ 6.163005] 2230 52802101 9100b3e2 2a010061 f802c3ff b90037ff 97fffe28 35000320 3902b27f
[ 6.163017] 2250 b940a660 321c0000 1400000a 321d0061 9100b3e2 f802c3ff b90037ff 97fffe1e
[ 6.163025] 2270* 350001e0 3902b27f b940a660 121c7800 b900a660 d5384100 f9401fe2 f9428801
[ 6.163034] 2290 eb010042 d2800001 54000121 a94153f3 a8c47bfd d50323bf d65f03c0 d4210000
[ 6.163042] 22b0 3902b27f 35fffcf4 17fffff0 9418b76d d503245f aa1e03e9 d503201f b940a403
[ 6.163051] 22d0 52840304 0a040063 7100207f 54000141 d503233f a9bf7bfd 12001c21 910003fd
[ 6.163060] 22f0 12001c42 97ffffbf a8c17bfd d50323bf d65f03c0 d65f03c0 d503201f d503201f
[ 6.163068] 2310 aa1e03e9 d503201f d503233f a9b87bfd d5384102 910003fd a90153f3 aa0003f3
[ 6.163076] 2330 a9025bf5 a90363f7 2a0103f8 a9046bf9 f9428840 f9003fe0 d2800000 b940a660
[ 6.163085] 2350 f9401e76 f9404e75 37000ec0 b9449aa1 aa1503f9 3942aa62 36500901 39c00ac1
[ 6.163094] 2370 36f808c1 7100045f 54000889 37600dc0 a90573fb 39400ec0 12000400 7100041f
[ 6.163103] 2390 54002d40 7100081f 540030a0 71000c1f 54003201 5280003c 52800814 b9442b21
[ 6.163111] 23b0 52866640 39512737 6b00003f 54000081 b9446320 12180400 2a0002f7 b9444f20
[ 6.163120] 23d0 53037ef7 36b02d20 7948cb3a 531f7ae2 0b1402f4 51000442 b944a73b f941cb20
[ 6.163128] 23f0 52986001 1b1c0a94 97fff776 12103c03 b9442b21 528aa660 1ad70a94 0b1b4063
[ 6.163136] 2410 6b00003f 12003a80 0b342361 0b1b0000 2a140063 1a811014 6b1a029f 54002f42
[ 6.163145] 2430 3942aa62 52861800 f941cb21 0b420402 531e7442 d50332bf 92981fe0 8b22c000
[ 6.163153] 2450 8b000020 b9000003 d503201f b940a660 32140000 b900a660 b904a734 b944ab20
[ 6.163162]
X10: 0xffffffffffff3f04:
[ 6.163165] 3d04 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163175] 3d24 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163185] 3d44 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163194] 3d64 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163203] 3d84 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163212] 3da4 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163222] 3dc4 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163231] 3de4 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163240] 3e04 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163250] 3e24 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163259] 3e44 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163268] 3e64 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163277] 3e84 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163286] 3ea4 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163297] 3ec4 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163307] 3ee4 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163323] 3f04* ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163332] 3f24 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163342] 3f44 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163351] 3f64 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163360] 3f84 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163370] 3fa4 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163379] 3fc4 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163388] 3fe4 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163398] 4004 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163407] 4024 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163416] 4044 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163426] 4064 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163435] 4084 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163444] 40a4 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163454] 40c4 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163464] 40e4 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163473]
X12: 0xffffffffffff3f08:
[ 6.163476] 3d08 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163485] 3d28 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163495] 3d48 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163504] 3d68 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163513] 3d88 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163523] 3da8 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163532] 3dc8 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163542] 3de8 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163551] 3e08 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163561] 3e28 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163570] 3e48 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163580] 3e68 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163589] 3e88 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163599] 3ea8 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163608] 3ec8 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163618] 3ee8 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163627] 3f08* ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163638] 3f28 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163650] 3f48 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163659] 3f68 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163668] 3f88 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163678] 3fa8 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163687] 3fc8 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163697] 3fe8 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163706] 4008 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163716] 4028 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163726] 4048 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163735] 4068 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163743] 4088 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163753] 40a8 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163763] 40c8 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163773] 40e8 ******** ******** ******** ******** ******** ******** ******** ********
[ 6.163783]
X14: 0xffffffc011e08df0:
[ 6.163786] 8bf0 00000000 00000000 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.163794] 8c10 00000000 00000000 11e08c18 ffffffc0 11e08c18 ffffffc0 0000001e 00000000
[ 6.163802] 8c30 00000000 00000000 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.163811] 8c50 00000000 00000000 11e08c58 ffffffc0 11e08c58 ffffffc0 00000000 00000000
[ 6.163820] 8c70 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[ 6.163828] 8c90 11e08c90 ffffffc0 11e08c90 ffffffc0 0000005a 00400000 00000064 00000000
[ 6.163836] 8cb0 ffffffff 00000001 00000000 00000000 00000000 dead4ead ffffffff 00000000
[ 6.163845] 8cd0 ffffffff ffffffff 00000000 00000000 11e08ce0 ffffffc0 11e08ce0 ffffffc0
[ 6.163853] 8cf0 11e08d30 ffffffc0 00000000 00000000 00000000 dead4ead ffffffff 00000000
[ 6.163862] 8d10 ffffffff ffffffff 00000000 00000000 11e08d20 ffffffc0 11e08d20 ffffffc0
[ 6.163870] 8d30 109cfb30 ffffffc0 100ab5d0 ffffffc0 00000000 00000000 00000000 00000000
[ 6.163879] 8d50 00000000 00000000 00000000 00000000 00000000 00000000 1147bfe0 ffffffc0
[ 6.163887] 8d70 100ab5b0 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.163896] 8d90 00000000 00000000 00000000 00000000 00000000 00000000 1147bfe8 ffffffc0
[ 6.163904] 8db0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.163913] 8dd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.163921] 8df0* 00000020 0000ba7e 1114be30 ffffffc0 00000020 00000000 fffea070 00000000
[ 6.163930] 8e10 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000001 00000000
[ 6.163941] 8e30 11611089 ffffffc0 00000001 00000000 116110a9 ffffffc0 00000000 00000000
[ 6.163954] 8e50 116110b8 ffffffc0 00000001 00000000 116110c9 ffffffc0 00000001 00000000
[ 6.163964] 8e70 116110d9 ffffffc0 00000001 00000000 116110e9 ffffffc0 00000000 00000000
[ 6.163973] 8e90 116110f8 ffffffc0 00000000 00000000 11611148 ffffffc0 00000001 00000000
[ 6.163981] 8eb0 00000001 00000000 00000001 00000000 11611159 ffffffc0 00000000 00000000
[ 6.163991] 8ed0 11611168 ffffffc0 00000001 00000000 11611179 ffffffc0 00000000 00000000
[ 6.163999] 8ef0 11611188 ffffffc0 00000001 00000000 11611199 ffffffc0 00000000 00000000
[ 6.164007] 8f10 116111b8 ffffffc0 00000000 00000000 116111d8 ffffffc0 00000001 00000000
[ 6.164016] 8f30 116111e9 ffffffc0 00000001 00000000 11611229 ffffffc0 00000001 00000000
[ 6.164028] 8f50 11611239 ffffffc0 00000001 00000000 11611249 ffffffc0 00000001 00000000
[ 6.164036] 8f70 11611269 ffffffc0 00000001 00000000 11611339 ffffffc0 00000001 00000000
[ 6.164044] 8f90 11611349 ffffffc0 00000001 00000000 11611359 ffffffc0 1147d4d0 ffffffc0
[ 6.164053] 8fb0 00000000 00000000 00000000 0000016d 00332c00 ffffff81 00000000 00000000
[ 6.164062] 8fd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164072]
X18: 0xffffffff04291300:
[ 6.164074] 1100 00020011 80000000 042910c8 ffffffff 04291148 ffffffff 10a2ec88 ffffff81
[ 6.164085] 1120 0000230f 00000000 00000000 00000000 ffffffff 00000001 0fc4b000 ffffff81
[ 6.164095] 1140 00020011 80000000 04291108 ffffffff 06503420 ffffff81 10a2ec88 ffffff81
[ 6.164103] 1160 00002310 00000000 00000000 00000000 ffffffff 00000001 0fc4b000 ffffff81
[ 6.164112] 1180 00020001 80000000 00000100 dead0000 00000122 dead0000 10a2ec88 ffffff81
[ 6.164121] 11a0 00002311 00000000 00000000 00000000 ffffffff 00000002 0fc4b000 ffffff81
[ 6.164132] 11c0 00020001 80000000 00000100 dead0000 00000122 dead0000 10a2ec88 ffffff81
[ 6.164140] 11e0 00002312 00000000 00000000 00000000 ffffffff 00000002 0fc4b000 ffffff81
[ 6.164149] 1200 00020001 80000000 00000100 dead0000 00000122 dead0000 10a2ec88 ffffff81
[ 6.164157] 1220 00002313 00000000 00000000 00000000 ffffffff 00000002 0fc4b000 ffffff81
[ 6.164165] 1240 00020001 80000000 00000100 dead0000 00000122 dead0000 10a2ec88 ffffff81
[ 6.164173] 1260 00002314 00000000 00000000 00000000 ffffffff 00000002 0fc4b000 ffffff81
[ 6.164182] 1280 00020001 80000000 00000100 dead0000 00000122 dead0000 10a2ec88 ffffff81
[ 6.164190] 12a0 00002315 00000000 00000000 00000000 ffffffff 00000002 0fc4b000 ffffff81
[ 6.164198] 12c0 00060001 80000000 00000100 dead0000 00000122 dead0000 10a2ec88 ffffff81
[ 6.164207] 12e0 00002316 00000000 00000000 00000000 ffffffff 00000002 0fc4b000 ffffff81
[ 6.164215] 1300* 00020001 80000000 00000100 dead0000 00000122 dead0000 10a2ec88 ffffff81
[ 6.164224] 1320 00002317 00000000 00000000 00000000 ffffffff 00000002 0fc4b000 ffffff81
[ 6.164232] 1340 00020001 80000000 00000100 dead0000 00000122 dead0000 10a2ec88 ffffff81
[ 6.164240] 1360 00002318 00000000 00000000 00000000 ffffffff 00000002 0fc4b000 ffffff81
[ 6.164249] 1380 00020001 80000000 00000100 dead0000 00000122 dead0000 10a2ec88 ffffff81
[ 6.164258] 13a0 00002319 00000000 00000000 00000000 ffffffff 00000002 0fc4b000 ffffff81
[ 6.164266] 13c0 00020001 80000000 00000100 dead0000 00000122 dead0000 10a2ec88 ffffff81
[ 6.164274] 13e0 0000231a 00000000 00000000 00000000 ffffffff 00000002 0fc4b000 ffffff81
[ 6.164284] 1400 00020001 80000000 00000100 dead0000 00000122 dead0000 10a2ec88 ffffff81
[ 6.164293] 1420 0000231b 00000000 00000000 00000000 ffffffff 00000002 0fc4b000 ffffff81
[ 6.164303] 1440 00020001 80000000 00000100 dead0000 00000122 dead0000 10a2ec88 ffffff81
[ 6.164311] 1460 0000231c 00000000 00000000 00000000 ffffffff 00000002 0fc4b000 ffffff81
[ 6.164320] 1480 00020001 80000000 00000100 dead0000 00000122 dead0000 10a2ec88 ffffff81
[ 6.164331] 14a0 0000231d 00000000 00000000 00000000 ffffffff 00000002 0fc4b000 ffffff81
[ 6.164340] 14c0 00000000 80000000 04291508 ffffffff f6ddda20 ffffff82 00000000 00000000
[ 6.164350] 14e0 00000001 00000000 00000000 00000000 ffffffff 00000000 00000000 00000000
[ 6.164361]
X19: 0xffffff81040aea00:
[ 6.164364] e800 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 040ae818 ffffff81
[ 6.164375] e820 040ae818 ffffff81 10992044 ffffffc0 10992120 ffffffc0 00000000 00000000
[ 6.164384] e840 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164392] e860 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164400] e880 00000000 00000000 00000000 00000000 00000000 00000000 0126b4c8 ffffff81
[ 6.164409] e8a0 041920a0 ffffff81 040ad9a0 ffffff81 00000001 00000000 040ae8b8 ffffff81
[ 6.164418] e8c0 040ae8b8 ffffff81 00000000 00000000 00000000 00000000 040b6830 ffffff81
[ 6.164429] e8e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164440] e900 01591f18 ffffff81 040ae700 ffffff81 109a0440 ffffffc0 115502c8 ffffffc0
[ 6.164459] e920 00000018 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164472] e940 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164480] e960 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164488] e980 036ea400 ffffff81 040ae688 ffffff81 040ae688 ffffff81 00000000 00000000
[ 6.164497] e9a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164506] e9c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164514] e9e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164522] ea00* 054edc58 ffffff81 040aeab8 ffffff81 112af378 ffffffc0 00000000 00000000
[ 6.164531] ea20 00000000 00000000 00000021 02000000 00000200 00000004 11ff7570 ffffffc0
[ 6.164540] ea40 00000000 00000000 00000000 00000000 040aea50 ffffff81 040aea50 ffffff81
[ 6.164549] ea60 040aea60 ffffff81 040aea60 ffffff81 040aea70 ffffff81 040aea70 ffffff81
[ 6.164558] ea80 1400c900 ffffffc0 00000000 00000000 00000000 00000000 040a4080 ffffff81
[ 6.164567] eaa0 00000000 00000009 00000000 00000000 00000000 00000000 6f307065 00007475
[ 6.164576] eac0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164584] eae0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164592] eb00 00000000 00000000 040aebb8 ffffff81 112af378 ffffffc0 00000000 00000000
[ 6.164601] eb20 00000000 00000000 00000011 02000000 00000200 00000004 11ff7570 ffffffc0
[ 6.164611] eb40 00000000 00000000 00000000 00000000 040aeb50 ffffff81 040aeb50 ffffff81
[ 6.164619] eb60 040aeb60 ffffff81 040aeb60 ffffff81 040aeb70 ffffff81 040aeb70 ffffff81
[ 6.164628] eb80 1400c910 ffffffc0 00000000 00000000 00000000 00000000 040a4080 ffffff81
[ 6.164636] eba0 00000000 00000001 00010000 00000000 00000000 00000000 69307065 0000006e
[ 6.164645] ebc0 00000000 00000000 00000000 00000001 00000000 00000000 00000000 00000000
[ 6.164653] ebe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164662]
X21: 0xffffff81040a41c0:
[ 6.164665] 3fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164673] 3fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164681] 4000 0409f500 ffffff81 0402e318 ffffff81 109a0440 ffffffc0 115502c8 ffffffc0
[ 6.164690] 4020 000004b8 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164698] 4040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164707] 4060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164715] 4080 00000140 00000000 040a4088 ffffff81 040a4088 ffffff81 10aeb650 ffffffc0
[ 6.164724] 40a0 12c4d000 ffffffc0 12c55000 ffffffc0 00000000 00000000 040c8000 ffffff81
[ 6.164732] 40c0 0a420000 00000000 0a421000 00000000 00000000 00000000 00000000 00000000
[ 6.164742] 40e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164751] 4100 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164759] 4120 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164768] 4140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164779] 4160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164787] 4180 00000000 00000000 00000000 00000000 00000001 00000000 00000000 dead4ead
[ 6.164795] 41a0 ffffffff 00000000 ffffffff ffffffff 040a41b0 ffffff81 040a41b0 ffffff81
[ 6.164803] 41c0* 00000001 dead4ead 00000006 00000000 010c0f00 ffffff81 00000000 00000000
[ 6.164812] 41e0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[ 6.164821] 4200 040a4200 ffffff81 040a4200 ffffff81 0402e010 ffffff81 0402e010 ffffff81
[ 6.164829] 4220 00000000 00000000 fc000000 00000000 fc007fff 00000000 fef0d730 ffffff82
[ 6.164838] 4240 00000200 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164846] 4260 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164854] 4280 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164862] 42a0 00000000 00000000 0409f980 ffffff81 040aea00 ffffff81 040aeb00 ffffff81
[ 6.164871] 42c0 040aec00 ffffff81 040aed00 ffffff81 040aee00 ffffff81 040aef00 ffffff81
[ 6.164879] 42e0 040af000 ffffff81 040af100 ffffff81 040af200 ffffff81 040af300 ffffff81
[ 6.164888] 4300 040af400 ffffff81 040af500 ffffff81 040af600 ffffff81 040af700 ffffff81
[ 6.164896] 4320 040af800 ffffff81 040af900 ffffff81 00000000 00000000 00000000 00000000
[ 6.164905] 4340 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164915] 4360 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164924] 4380 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164933] 43a0 00000000 00000000 00000000 00000000 040b6c00 ffffff81 054edb60 ffffff81
[ 6.164942]
X23: 0xffffff810162ebc8:
[ 6.164946] e9c8 0162e9c8 ffffff81 0162e9c8 ffffff81 00000000 00000000 00000000 00000000
[ 6.164954] e9e8 0162e9e8 ffffff81 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.164963] ea08 00000000 00000000 109ae8a0 ffffffc0 f6dab080 ffffff82 00000000 00000000
[ 6.164971] ea28 00000000 00000000 ffffffe0 0000000f 0162ea38 ffffff81 0162ea38 ffffff81
[ 6.164979] ea48 109ae930 ffffffc0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.164989] ea68 0162ea68 ffffff81 0162ea68 ffffff81 00000000 00000000 00000000 00000000
[ 6.164997] ea88 00000081 00000000 00000000 00000002 00000000 00000000 00000000 00000000
[ 6.165005] eaa8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165014] eac8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165022] eae8 00000000 00000000 00000000 00000000 0162eaf8 ffffff81 0162eaf8 ffffff81
[ 6.165030] eb08 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165039] eb28 00000000 00000000 00000000 00000000 0162eb38 ffffff81 0162eb38 ffffff81
[ 6.165048] eb48 00000000 00000000 00000000 00000000 fef1ada0 ffffff82 00000000 00000000
[ 6.165056] eb68 00000000 00000000 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.165064] eb88 0162eb88 ffffff81 0162eb88 ffffff81 00000000 00000000 00000000 00000000
[ 6.165073] eba8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165082] ebc8* 109b69e4 ffffffc0 109b6780 ffffffc0 00000000 00000000 00000000 00000000
[ 6.165090] ebe8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165098] ec08 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165106] ec28 00000000 00000000 00000000 00000000 109b9944 ffffffc0 109b8ef0 ffffffc0
[ 6.165115] ec48 109b6920 ffffffc0 109b6854 ffffffc0 109b98c0 ffffffc0 109b8dd0 ffffffc0
[ 6.165123] ec68 109bb2b0 ffffffc0 109bab20 ffffffc0 00000000 00000000 109b6220 ffffffc0
[ 6.165132] ec88 109b9d60 ffffffc0 00000000 00000000 109b66f0 ffffffc0 00000000 00000000
[ 6.165140] eca8 0162e4a8 ffffff81 0162f4a8 ffffff81 0162ecb8 ffffff81 0162ecb8 ffffff81
[ 6.165148] ecc8 0162ecc8 ffffff81 0162ecc8 ffffff81 04076400 ffffff81 04093700 ffffff81
[ 6.165157] ece8 00000000 00000000 00000100 00000000 0162ecf8 ffffff81 0162ecf8 ffffff81
[ 6.165165] ed08 109bb220 ffffffc0 fef1adb8 ffffff82 00000001 00000000 11592b68 ffffffc0
[ 6.165173] ed28 00000000 00000000 00000006 00000000 00000000 00000000 00000000 00000000
[ 6.165182] ed48 10796c00 ffffffc0 10796bc0 ffffffc0 00000000 00000000 00000000 00000000
[ 6.165190] ed68 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165199] ed88 ffffffff ffffffff 00000000 00000000 00000001 00000000 10795da0 ffffffc0
[ 6.165208] eda8 10795d30 ffffffc0 00000008 00000000 015c0080 ffffff81 109b6750 ffffffc0
[ 6.165217]
X24: 0xffffff8104076400:
[ 6.165220] 6200 30306366 30303030 6273752e 00000000 0402e010 ffffff81 04076218 ffffff81
[ 6.165232] 6220 04076218 ffffff81 00000000 00000000 04076230 ffffff81 04076230 ffffff81
[ 6.165241] 6240 04076380 ffffff81 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165250] 6260 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165258] 6280 736e6f63 72656d75 616c703a 726f6674 63663a6d 30303030 752e3030 79006273
[ 6.165267] 62a0 30306340 2d322e30 616c702d 726f6674 63663a6d 30303838 752e3030 ff006273
[ 6.165280] 62c0 04076300 ffffff81 ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
[ 6.165289] 62e0 ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
[ 6.165297] 6300 70707573 7265696c 616c703a 726f6674 64663a6d 30386438 702e3030 7265776f
[ 6.165305] 6320 6e616d2d 6d656761 3a746e65 65776f70 6f632d72 6f72746e 72656c6c 00000000
[ 6.165313] 6340 04076380 ffffff81 66667562 312d7265 00003832 00000000 00000000 00000000
[ 6.165322] 6360 00000000 00000000 01581ac8 ffffff81 040764e8 ffffff81 00000000 00000000
[ 6.165331] 6380 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000002 00000000
[ 6.165339] 63a0 040763a0 ffffff81 040763a0 ffffff81 04076400 ffffff81 00000000 00000000
[ 6.165348] 63c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165356] 63e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165365] 6400* 0407b280 ffffff81 0162ecd8 ffffff81 0402e010 ffffff81 00005a02 00000000
[ 6.165373] 6420 007dac34 00000000 fffffc18 000001f3 00000001 00000000 109b6150 ffffffc0
[ 6.165382] 6440 00000000 00000000 00000000 00000000 00000000 00000000 ffffffff 00000000
[ 6.165392] 6460 ffffffff 7fffffff 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165401] 6480 fc00c100 00000000 fc3fffff 00000000 0409f580 ffffff81 80000200 00000000
[ 6.165409] 64a0 00000000 00000000 11e01618 ffffffc0 0407bb00 ffffff81 00000000 00000000
[ 6.165417] 64c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165425] 64e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165434] 6500 00000000 00000000 14000000 ffffffc0 003f5000 00000000 00000001 00000000
[ 6.165443] 6520 00000000 00000000 00000000 00000000 fc00c000 00000000 10649eb8 ffffffc0
[ 6.165459] 6540 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165472] 6560 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165481] 6580 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165489] 65a0 00010000 00000000 00000000 00000000 00000001 00000000 04076600 ffffff81
[ 6.165498] 65c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165506] 65e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165514]
X26: 0xffffffc011de7000:
[ 6.165517] 6e00 ffffffff ffffffff 11de6e08 ffffffc0 11de6e08 ffffffc0 00000000 dead4ead
[ 6.165526] 6e20 ffffffff 00000000 ffffffff ffffffff 11de6e30 ffffffc0 11de6e30 ffffffc0
[ 6.165534] 6e40 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 11de6e58 ffffffc0
[ 6.165542] 6e60 11de6e58 ffffffc0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.165551] 6e80 11de6e80 ffffffc0 11de6e80 ffffffc0 00000000 dead4ead ffffffff 00000000
[ 6.165558] 6ea0 ffffffff ffffffff 11de6ea8 ffffffc0 11de6ea8 ffffffc0 00000000 dead4ead
[ 6.165567] 6ec0 ffffffff 00000000 ffffffff ffffffff 11de6ed0 ffffffc0 11de6ed0 ffffffc0
[ 6.165575] 6ee0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 11de6ef8 ffffffc0
[ 6.165583] 6f00 11de6ef8 ffffffc0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.165591] 6f20 11de6f20 ffffffc0 11de6f20 ffffffc0 00000000 dead4ead ffffffff 00000000
[ 6.165599] 6f40 ffffffff ffffffff 11de6f48 ffffffc0 11de6f48 ffffffc0 00000000 dead4ead
[ 6.165607] 6f60 ffffffff 00000000 ffffffff ffffffff 11de6f70 ffffffc0 11de6f70 ffffffc0
[ 6.165615] 6f80 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 11de6f98 ffffffc0
[ 6.165624] 6fa0 11de6f98 ffffffc0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.165632] 6fc0 11de6fc0 ffffffc0 11de6fc0 ffffffc0 00000000 dead4ead ffffffff 00000000
[ 6.165640] 6fe0 ffffffff ffffffff 11de6fe8 ffffffc0 11de6fe8 ffffffc0 00000000 dead4ead
[ 6.165648] 7000* ffffffff 00000000 ffffffff ffffffff 11de7010 ffffffc0 11de7010 ffffffc0
[ 6.165656] 7020 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 11de7038 ffffffc0
[ 6.165664] 7040 11de7038 ffffffc0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.165673] 7060 11de7060 ffffffc0 11de7060 ffffffc0 00000000 dead4ead ffffffff 00000000
[ 6.165682] 7080 ffffffff ffffffff 11de7088 ffffffc0 11de7088 ffffffc0 00000000 dead4ead
[ 6.165690] 70a0 ffffffff 00000000 ffffffff ffffffff 11de70b0 ffffffc0 11de70b0 ffffffc0
[ 6.165699] 70c0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 11de70d8 ffffffc0
[ 6.165707] 70e0 11de70d8 ffffffc0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.165715] 7100 11de7100 ffffffc0 11de7100 ffffffc0 00000000 dead4ead ffffffff 00000000
[ 6.165724] 7120 ffffffff ffffffff 11de7128 ffffffc0 11de7128 ffffffc0 00000000 dead4ead
[ 6.165732] 7140 ffffffff 00000000 ffffffff ffffffff 11de7150 ffffffc0 11de7150 ffffffc0
[ 6.165741] 7160 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 11de7178 ffffffc0
[ 6.165749] 7180 11de7178 ffffffc0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.165758] 71a0 11de71a0 ffffffc0 11de71a0 ffffffc0 00000000 dead4ead ffffffff 00000000
[ 6.165768] 71c0 ffffffff ffffffff 11de71c8 ffffffc0 11de71c8 ffffffc0 00000000 dead4ead
[ 6.165777] 71e0 ffffffff 00000000 ffffffff ffffffff 11de71f0 ffffffc0 11de71f0 ffffffc0
[ 6.165786]
X27: 0xffffffc011e048a0:
[ 6.165788] 46a0 00000010 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165798] 46c0 1005ebc0 ffffffc0 1005eb30 ffffffc0 00000000 00000000 033be901 ffffff81
[ 6.165807] 46e0 00000000 00000000 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.165815] 4700 11e04700 ffffffc0 11e04700 ffffffc0 0000fffe 0000fffe 0000fffe 0000fffe
[ 6.165824] 4720 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dead4ead
[ 6.165832] 4740 ffffffff 00000000 ffffffff ffffffff 11e04750 ffffffc0 11e04750 ffffffc0
[ 6.165840] 4760 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 11e04778 ffffffc0
[ 6.165849] 4780 11e04778 ffffffc0 00000000 00000000 00000000 dead4ead ffffffff 00000000
[ 6.165857] 47a0 ffffffff ffffffff ffffffff 000001ff ffffffff 000001ff 00000000 dead4ead
[ 6.165866] 47c0 ffffffff 00000000 ffffffff ffffffff 11e047d0 ffffffc0 11e047d0 ffffffc0
[ 6.165874] 47e0 11479c78 ffffffc0 00000001 00000000 00000010 00000180 00000000 00000000
[ 6.165882] 4800 1006d1d0 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165891] 4820 11479c80 ffffffc0 00000002 00000000 00000010 00000180 00000000 00000000
[ 6.165899] 4840 1006d1d0 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165908] 4860 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165916] 4880 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165924] 48a0* 00000000 00000000 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.165932] 48c0 00000000 00000000 11e048c8 ffffffc0 11e048c8 ffffffc0 00000000 00000000
[ 6.165941] 48e0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[ 6.165949] 4900 11e04900 ffffffc0 11e04900 ffffffc0 115c68a0 ffffffc0 00000000 00000000
[ 6.165957] 4920 00e12000 ffffff81 00000000 00000000 11e04b08 ffffffc0 00000000 00000000
[ 6.165966] 4940 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165975] 4960 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165984] 4980 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.165992] 49a0 00000000 00000000 00000000 00000000 00e11c00 ffffff81 00000000 00000000
[ 6.166006] 49c0 11488218 ffffffc0 000001a4 00000000 1006e4d0 ffffffc0 10074dc0 ffffffc0
[ 6.166015] 49e0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 04000004 00000000
[ 6.166023] 4a00 00400002 ffffff81 00000000 00000000 00000000 dead4ead ffffffff 00000000
[ 6.166031] 4a20 ffffffff ffffffff 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 6.166040] 4a40 11e04a40 ffffffc0 11e04a40 ffffffc0 00020610 ffffff81 0178be10 ffffff81
[ 6.166048] 4a60 1147a248 ffffffc0 00000124 00000000 1006e764 ffffffc0 00000000 00000000
[ 6.166058] 4a80 1147a258 ffffffc0 000001a4 00000000 1006e6f0 ffffffc0 100733f0 ffffffc0
[ 6.166067]
X28: 0xffffffc01210c748:
[ 6.166069] c548 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166078] c568 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166086] c588 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166094] c5a8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166102] c5c8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166110] c5e8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166118] c608 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166126] c628 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166135] c648 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166144] c668 00000000 00000000 00000000 00000000 00fb1038 ffffff81 0c9ce038 ffffff81
[ 6.166151] c688 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166160] c6a8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166168] c6c8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166176] c6e8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166184] c708 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166193] c728 00000000 00000000 00000000 00000000 00359500 ffffff81 00000000 00000000
[ 6.166201] c748* 00002500 ffffff81 000000ff 00000000 00000000 00000000 00000000 00000000
[ 6.166210] c768 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166218] c788 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166227] c7a8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166236] c7c8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166244] c7e8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166256] c808 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166264] c828 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166273] c848 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166281] c868 00f642f8 ffffff81 00000000 00000000 000382f8 ffffff81 00000000 00000000
[ 6.166289] c888 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166298] c8a8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166306] c8c8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166314] c8e8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166326] c908 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166334] c928 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.166343]
X29: 0xffffffc0125dbb30:
[ 6.166345] b930 125db9e0 ffffffc0 125dba10 ffffffc0 125db960 ffffffc0 1002b4e8 ffffffc0
[ 6.166354] b950 125db9e0 ffffffc0 00000001 00000000 125db9a0 ffffffc0 1111f0e4 ffffffc0
[ 6.166362] b970 125db9e0 ffffffc0 f2000800 00000000 88ce7bf4 0000007f 10af22ac ffffffc0
[ 6.166370] b990 125db9a0 ffffffc0 1111f0d4 ffffffc0 125db9d0 ffffffc0 1111f528 ffffffc0
[ 6.166379] b9b0 040aea00 ffffff81 ffffffff 0000007f 125dbb30 ffffffc0 100a96a0 ffffffc0
[ 6.166388] b9d0 125dbb10 ffffffc0 1000240c ffffffc0 ffffff92 00000000 14000100 ffffffc0
[ 6.166396] b9f0 00000000 00000000 00101448 00000000 11dea000 ffffffc0 ffff3f0c ffffffff
[ 6.166405] ba10 08ceb846 00000000 ffff3f0c ffffffff ffff3f00 ffffffff 10af2270 ffffffc0
[ 6.166413] ba30 ffff3f04 ffffffff 83307d70 01b08602 ffff3f08 ffffffff 00006f0f 00000000
[ 6.166422] ba50 11e08df0 ffffffc0 01b9fe98 00000000 0172d858 00000000 00000001 00000000
[ 6.166430] ba70 04291300 ffffffff 040aea00 ffffff81 00000000 00000000 040a41c0 ffffff81
[ 6.166438] ba90 00000000 00000000 0162ebc8 ffffff81 04076400 ffffff81 ca42691f 00000000
[ 6.166449] bab0 11de7000 ffffffc0 11e048a0 ffffffc0 1210c748 ffffffc0 125dbb30 ffffffc0
[ 6.166461] bad0 10af2270 ffffffc0 125dbb30 ffffffc0 10af22ac ffffffc0 20c00089 00000000
[ 6.166478] baf0 0162ebc8 ffffff81 04076400 ffffff81 ffffffff ffffffff 11de7000 ffffffc0
[ 6.166490] bb10 125dbb30 ffffffc0 10af22ac ffffffc0 00000000 00000000 11128ab4 00000040
[ 6.166499] bb30* 125dbb70 ffffffc0 10af426c ffffffc0 040aea00 ffffff81 040a4080 ffffff81
[ 6.166507] bb50 040b6c00 ffffff81 102698bc 00000000 00000000 00000000 f4059800 b37418ae
[ 6.166516] bb70 125dbb90 ffffffc0 10af5a44 ffffffc0 040aea00 ffffff81 040a4080 ffffff81
[ 6.166524] bb90 125dbbb0 ffffffc0 10af6d94 ffffffc0 040a4080 ffffff81 00000000 00000000
[ 6.166533] bbb0 125dbbd0 ffffffc0 10aeb220 ffffffc0 040a4080 ffffff81 10096e20 ffffffc0
[ 6.166541] bbd0 125dbc00 ffffffc0 10aeb37c ffffffc0 0402e010 ffffff81 0402e010 ffffff81
[ 6.166550] bbf0 0162e880 ffffff81 100fa334 ffffffc0 125dbc20 ffffffc0 109a99e8 ffffffc0
[ 6.166559] bc10 0402e010 ffffff81 109bb2b0 ffffffc0 125dbc30 ffffffc0 109bb364 ffffffc0
[ 6.166568] bc30 125dbc80 ffffffc0 109ac698 ffffffc0 0402e010 ffffff81 109bb2b0 ffffffc0
[ 6.166576] bc50 109bb2b0 ffffffc0 0402e110 ffffff81 00000000 00000000 11122b00 ffffffc0
[ 6.166586] bc70 000f4240 00000000 109ac6d0 ffffffc0 125dbcc0 ffffffc0 109ac7dc ffffffc0
[ 6.166595] bc90 0402e010 ffffff81 109bb2b0 ffffffc0 00000008 00000000 00000000 00000000
[ 6.166603] bcb0 0000000a 00000000 109ae188 ffffffc0 125dbcf0 ffffffc0 109ae1e0 ffffffc0
[ 6.166611] bcd0 0402e010 ffffff81 109bb2b0 ffffffc0 0000000a 00000000 11122b00 ffffffc0
[ 6.166620] bcf0 125dbd70 ffffffc0 109aea00 ffffffc0 0402e1c0 ffffff81 0402e110 ffffff81
[ 6.166629] bd10 f6dd6100 ffffff82 f6ddec00 ffffff82 00000000 00000000 0402e1c8 ffffff81
[ 6.166638] ---[ end trace 20ca0679232a5ac0 ]---
