Bluetooth In NanoPC-T3 board doesn't work with hcitool scan?
How to bluetooth work on Nano-PC T3, not see the device. ?
hcitool scan
I'm refer at site: http://wiki.friendlyarm.com/wiki/index.php/NanoPC-T3 but that's not work? why?
Attatchment the log:
root@nano:~# hcitool scan
Device is not available: No such device
root@nano:~#
root@nano:~# hcitool dev
Devices:
root@nano:~#
Regards,
HuyLe
Seeing the boot log to login
Debian GNU/Linux 8 nano ttySAC0
nano login: [ 24.192000] Bluetooth: RFCOMM socket layer initialized
[ 24.192000] Bluetooth: RFCOMM ver 1.11
[ 25.272000] bt_bcm: rfkill set_block Off GPIOB.8
Debian GNU/Linux 8 huyle ttySAC0
huyle login: root
Password:
Last login: Sun Apr 23 15:56:37 CST 2017 on ttySAC0
Linux nano 3.4.39-s5p6818 #4 SMP PREEMPT Wed Mar 1 11:51:02 HKT 2017 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@nano:~# dmesg | grep Blue
[ 5.164000] Bluetooth: Core ver 2.21
[ 5.168000] Bluetooth: HCI device and connection manager initialized
[ 5.176000] Bluetooth: HCI socket layer initialized
[ 5.180000] Bluetooth: L2CAP socket layer initialized
[ 5.184000] Bluetooth: SCO socket layer initialized
[ 5.200000] Bluetooth: HCI UART driver ver 2.3
[ 5.200000] Bluetooth: HCI UART protocol H4 registered
[ 5.200000] Bluetooth: HCI UART protocol BCM registered
[ 5.200000] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.200000] Bluetooth: BNEP filters: protocol multicast
[ 5.200000] Bluetooth: BNEP socket layer initialized
root@nano:~# dmesg | grep bt_bcm
[ 0.704000] bt_bcm: rfkill initialized
[ 5.044000] bt_bcm: rfkill set_block Off GPIOB.8
[ 16.124000] bt_bcm: rfkill set_block Off GPIOB.8
[ 16.200000] bt_bcm: rfkill set_block On GPIOB.8
root@nano:~#
Devices:
root@nano:~#
root@nano:~# rfkill unblock 0
[ 499.368000] bt_bcm: rfkill set_block On GPIOB.8
[ 500.164000] bt_bcm: rfkill set_block On GPIOB.8
[ 501.008000] bt_bcm: rfkill set_block On GPIOB.8
Devices:
root@nano:~#
--Regards,
HuyLe
I am not sure if you have solved this. Is hcitool installed on your system?
I noticed here https://packages.debian.org/search?searchon=contents&keywords=hcitool&mode=path&suite=stable&arch=any that maybe you need to:
sudo apt-get install bluez
Hi Davef,
Thanks to reply!
I'm sure the package is installed. The issue is why don't detect device controler ??
I checked on two boards NanoPC-T3 but still not seeing the device controler.
root@huyle:~#
root@huyle:~# sudo apt-get install bluetooth bluez blueman
Reading package lists... Done
Building dependency tree
blueman is already the newest version.
bluetooth is already the newest version.
bluez is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 201 not upgraded.
root@huyle:~# systemctl status bluetooth
�● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled)
Active: active (running) since Fri 2016-01-01 16:55:20 CST; 1 years 3 months ago
Docs: man:bluetoothd(8)
Main PID: 1144 (bluetoothd)
Status: "Running"
CGroup: /system.slice/bluetooth.service
�└�─1144 /usr/lib/bluetooth/bluetoothd
Jan 01 16:55:20 huyle bluetoothd[1144]: Bluetooth daemon 5.23
Jan 01 16:55:20 huyle systemd[1]: Started Bluetooth service.
Jan 01 16:55:20 huyle bluetoothd[1144]: Starting SDP server
Jan 01 16:55:20 huyle bluetoothd[1144]: Bluetooth management interface 1.10 ...d
Hint: Some lines were ellipsized, use -l to show in full.
root@huyle:~# hcitool dev
Devices:
root@huyle:~# systemctl status bluetooth -l
Status: "Running"
Jan 01 16:55:20 huyle bluetoothd[1144]: Bluetooth management interface 1.10 initialized
root@huyle:~# bluetoothctl
[bluetooth]# help
Available commands:
list List available controllers
show [ctrl] Controller information
select <ctrl> Select default controller
devices List available devices
power <on/off> Set controller power
pairable <on/off> Set controller pairable mode
discoverable <on/off> Set controller discoverable mode
agent <on/off/capability> Enable/disable agent with given capability
default-agent Set agent as the default one
scan <on/off> Scan for devices
info <dev> Device information
pair <dev> Pair with device
trust <dev> Trust device
remove <dev> Remove device
connect <dev> Connect device
disconnect <dev> Disconnect device
version Display version
quit Quit program
[bluetooth]# list
[bluetooth]# devices
[bluetooth]# power on
No default controller available
[bluetooth]# version
Version 5.9
[bluetooth]#
What do you get when you do:
sudo service --status-all
Attachment the log run service:
root@huyle:~#
��● bluetooth.service - Bluetooth service
Active: active (running) since Fri 2016-01-01 16:00:26 CST; 1 years 3 months ago
Main PID: 1145 (bluetoothd)
Status: "Running"
��└��─1145 /usr/lib/bluetooth/bluetoothd
Jan 01 16:00:26 huyle bluetoothd[1145]: Bluetooth daemon 5.23
Jan 01 16:00:26 huyle systemd[1]: Started Bluetooth service.
Jan 01 16:00:26 huyle bluetoothd[1145]: Starting SDP server
Jan 01 16:00:26 huyle bluetoothd[1145]: Bluetooth management interface 1.10 ...d
Devices:
root@huyle:~# sudo service --status-all
[ - ] alsa-utils
[ - ] apache2
[ + ] avahi-daemon
[ + ] avahi-dnsconfd
[ + ] bluetooth
[ - ] bootlogs
[ - ] bootmisc.sh
[ ? ] brcm_patchram_plus
[ - ] checkfs.sh
[ - ] checkroot-bootclean.sh
[ - ] checkroot.sh
[ - ] console-setup
[ + ] cron
[ + ] dbus
[ - ] dnsmasq
[ - ] gpsd
[ - ] hostapd
[ - ] hostname.sh
[ - ] hwclock.sh
[ - ] isc-dhcp-server
[ - ] keyboard-setup
[ - ] killprocs
[ + ] kmod
[ - ] lcd4linux
[ + ] lightdm
[ - ] motd
[ - ] mountall-bootclean.sh
[ - ] mountall.sh
[ - ] mountdevsubfs.sh
[ - ] mountkernfs.sh
[ - ] mountnfs-bootclean.sh
[ - ] mountnfs.sh
[ + ] network-manager
[ + ] networking
[ + ] nmbd
[ + ] ntp
[ - ] pppd-dns
[ + ] procps
[ + ] rc.local
[ + ] resolvconf
[ - ] rmnologin
[ - ] rsync
[ + ] rsyslog
[ - ] samba
[ + ] samba-ad-dc
[ - ] screen-cleanup
[ - ] sendsigs
[ - ] smbd
[ + ] ssh
[ - ] sudo
[ + ] tftpd-hpa
[ ? ] tightvncserver
[ + ] udev
[ + ] udev-finish
[ - ] udhcpd
[ + ] ufw
[ - ] umountfs
[ - ] umountnfs.sh
[ - ] umountroot
[ + ] urandom
[ + ] vsftpd
[ - ] x11-common
[ + ] xinetd
root@huyle:~# sudo service --status-all | grep bluetooth
[ + ] bluetooth
Devices:
root@huyle:~#
Dropping:
 brcm_patchram_plus
into Google turns up some possibly interesting reading.
Sorry, can't help further.
Good luck!
Ok Davef,
Thanks to disscussion. Will sent to you if bluetooth work.
--Regards,
HuyLe
